Old 02-25-2009, 06:41 PM
BIGTEX84's Avatar
BIGTEX84 BIGTEX84 is offline
Bitch pin
Does anyone have a better way to remove the bitch pin in the shift linkage? or the proper punch to use, its about a 1/4 of the way out i pounded on it for about 30 mins today and thats about as far as i could get it. any suggestions? i have to get this one out plus they just cut the linkage on the y1 tranny and i have to get that one out too. HELP!!!!
Hey, if you are looking for a good deal on a motor swap, with fast shipping and great customer service, Ive got just the place for you. . . . . . . . TO STAY AWAY FROM!!!!! WWW.OSAKAJDMMOTORS.COM=BULL$H!T!!!!
Old 02-25-2009, 06:55 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: Bitch pin
Drills don't work, you'll break the bits quick as you can get them started.
You really have to make sure you're hitting it in the right direction, as well. You should be knocking it from the top down, iirc. They're taper-fit. Most people use one of the bolts from the A/C pump, they're just the right size to fit the pin.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 02-25-2009, 08:06 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Bitch pin
8mm punch. Here's a whole thread on H-T about it, for more ideas:
http://honda-tech.com/showthread.php?t=470849
Old 02-25-2009, 09:35 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Bitch pin
It doesn't matter which way.
Old 02-26-2009, 05:51 PM
CivicSpoon's Avatar
There is no Spoon
Re: Bitch pin
Here's another link I saw today:
http://www.performanceforum.com/wesv...tch/bitch.html
Old 02-26-2009, 06:31 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Bitch pin
Easiest way:
Remove the bolt holding the other end of the linkage to the transmission. Use said bolt to punch bitch pin out.
Doesn't matter which way you go with it, just which ever you have more room to hit it with.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-26-2009, 08:43 PM
BIGTEX84's Avatar
Re: Bitch pin
thanks guys, i used the bolt for the shift stabilizer, put it in a 12mm socket, put all my extentions together, was able to get a good swing from up top, 2 hits, much thanxx
Old 02-26-2009, 10:35 PM
Tony's Avatar
TLD Member #1
Re: Bitch pin
not a problem. Everyone looks far away for something to use to knock that thing out...when its right there by it
Tony
Old 02-27-2009, 12:50 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Bitch pin
I usually use my handy hex driver socket on the end of a couple extensions. The ED chassis makes it easy to get to it from the top.. the EG etc do not.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-27-2009, 11:24 PM
Re: Bitch pin
Hell, I always assumed it was tapered, b/c I could never get it out going up from the bottom... two hits going down from the top, and it was done for.
I usually replace it w/ interference fit bolt that's been in the freezer the whole time I'm working on whatever reason I needed to take the stupid thing out. A bolt that isn't interference fit will allow the linkage to move slightly... I prefer tight shifts and no wobble-wear.
Old 02-28-2009, 03:09 AM
kris's Avatar
Re: Bitch pin
Buying a new expansion pin from Honda for a few bucks works just as well.
Old 02-28-2009, 08:12 AM
Re: Bitch pin
3 things:
1. They're cheaper at the local hardware store, and they're called "roll pins".
2. There is a reason I don't put it back in... same reason it's called a "bitch pin" to begin with. Bolt works fine, and it's alot easier to get back out.
3. Cynicism hasn't been funny since the invention of /B/.
Old 02-28-2009, 10:11 AM
kris's Avatar
Re: Bitch pin
3 things:
So you got me on a wording error. Kind of like saying you have to knock it from the top down.
Getting the pin out is not that tough. There are plenty of other ways than using a a hammer on a bolt. Using the wrong tool for the job results in a mushroomed pin which will of course give you grief while trying to put it back in.
I have replaced many hacked up ways that people can think of in securing the linkage. Everything from zip ties, to running a bolt through it. I have even seen your cheap hardware store pins fail, and offer sloppy results. So I will always use the correct pin for that, and I will always recommend the correct pin.
So while shadetree mechanics are great to talk about, more often than not cutting corners results in more problems down the road.
Old 02-28-2009, 12:38 PM
Tony's Avatar
TLD Member #1
Re: Bitch pin
I'm lazy and work on my car way to much to be putting a new pin everytime I need to take it apart. My fix does leave some slack in it, but its nothing that drives me nuts over. I just go to the hardware store and pick up a "trailer hitch" pin(can't remember the correct name) and a cotter pin. Not the best fix in the world, but if you have to do a lot of work on it, or a lot of quick work, its does its job. And if it never worked its way out running around on a rough as dirt track, it works for me. Only draw back from it is a little wiggle in the shifter, but not enough to screw you up.
Any way around it, there are several different ways to remove the pin and there are several ways to replace it. Choose which ever way you want, its your vehicle....just don't use zip ties.
Tony
Old 03-01-2009, 12:08 PM
BIGTEX84's Avatar
Re: Bitch pin
hahaha, zip ties! man that must feel as sloppy as my ex-fiance after an all nighter! But n e wayz, im just gonna put a new bitch pin in it. it wasnt that hard after i got some good info, much like my equipment not being that hard after i got some info on my ex-fiance!! lol, that cheatin bitch!!
