Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-25-2009, 12:10 AM
killerhawk70 killerhawk70 is offline
'98 crown vic valve cover help
ok, so i have a '98 4.6L crown vic. I attempted to remove the passenger side valve cover but am now stuck. All the bolts are out and there is not enough clearence for the cover to come off. The corner of the cover keeps getting stuck by this black box thing that the ac condenser plugs into. Can someone please help me by letting me know how to remove this cover?
Old 02-25-2009, 07:13 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: '98 crown vic valve cover help
Try removing the entire wiper module. This will gain you a little more access and the cover should lift straight up.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-13-2009, 10:57 AM
Bbodine64 Bbodine64 is offline
I ran into the same problem and here is what I did.
1. You have to make sure that ALL the wiring is out of the way.
2. Unplug the injectors (don't know if it helped or not, but it's easy enough to do)
3. Take the cover and rotate the bottom upward and rock it back and forth (front to back of the engine and up and down)
4. Make sure once the cover starts to come up you put more pressure towards teh back of the cover.
After I did that for a minute I was able to make it over the cam shaft bracket and pull the cover out towards the front of the car. I know this is a little late, but for everyone else I hope it helps.
