Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 02-24-2009, 03:27 PM
drew300 drew300 is offline
Replacing struts
I'm looking at replacing the old front struts (at 175,000 Km). As well as the struts, a site said the "strut mounts are a wear item". Do they go? Obviously, I don't want to take the car apart to find I need to order more parts.
What's normal to replace with the struts?
Thanks
Old 02-24-2009, 03:45 PM
Scrapper Scrapper is offline
AF Premium User
Re: Replacing struts
Thanks
i think there trieing to tell you that you should put the upper bearing plates on them when you replace the struts and there on the very top of the struts and if there waren you do need to replace them and do it right and not have to tear back down if you needed them in the first place.
RC1488 RC1488 is offline
The front mounts are a wear item. Each are $40 at autozone/AA. If you have the $$ id replace them. If not, then it should be ok with out them. Note when removing them from the spring, they may stick. Do NOT PULL on them, use a screwdriver and some PB blaster to slowly unstick them. If you pull on them, you can pull the mount apart (which can be put back together) but also shoots about 30 3mm ball all over your garage. I know this from experience
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 02-25-2009, 09:05 AM
Thanks for the replies.
I guess "do it once, right", applies.
BTW: the loose bearing sounds familiar.
Do you know that electrical things run on smoke? When you let the smoke out of the parts, they don't work anymore....
Old 02-25-2009, 11:18 PM
Cat Fuzz Cat Fuzz is offline
You might want to check and see if you can get complete strut assemblies. They include the strut, spring and bearing plate, all pre-assembled and ready to install. Easier and safer than swapping your springs over and the bearing plate is also covered.
Old 02-25-2009, 11:50 PM
eeeek thats got to be $$$$$$$$$ though no?
Old 02-26-2009, 10:39 AM
Yeah, they are more money but it makes the job much easier. Some people might not mind paying more for that.
