Old 02-24-2009, 12:05 PM
Grug Grug is offline
Whacking The Starter!!
When whacking the starter with the end of a broomstick makes it work...what does that usually mean? Starter? Solenoid? Brushes?
The starter seems to not work about 10% of the time, but if I give it a good firm poke with the end of a broomstick, it will work. A friend told me to try the broomstick trick, but before I go out and buy a new starter, I wanna' make sure there's not a cheaper solution.
By the way, it's starting to take an even harder whack these days. In the beginning it only took one good poke. Now it takes several really good pokes!
Thanks!
Old 02-24-2009, 12:20 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Whacking The Starter!!
It usually means the heavy duty internal contacts are burnt, dirty, or nearly worn out-lots of times you could tear it apart and sand them down and be happy. Typically, they can't transfer the amps necessary to turn the starter motor- I have done it to my truck - 454 Dually- about a year ago- I had to do it about 3 different times- and haven't done it since. My '94 Astro, I had to do it twice in the last 6 months- so as you can see it can get worse, or it can nearly resolve itself. My dually is only used maybe once in two weeks, my van gets started 5 or 6 times a day.
Oh by the way, I use a crowbar to tap on it while someone else holds the key in the start position- usually just takes one good tap. I will replace it when it gets to be a real problem...If you really don't want to get stuck- then it would be good to replace it-- I tap on it primarily to use that as a diagnostic tool- so I know exactly what needs to be fixed in the start system....then I'll decide what to do about it- right now- do to money contraints, the crowbar is under the seat...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-25-2009, 07:04 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Put a new starter on it and be done with it.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 07-08-2009, 07:10 PM
THOM HAGGIS THOM HAGGIS is offline
before replacing starter check the wire to the solenoid on top very bad for poor connection.they usually are worse in cold weather (METAL AND CONNECTORS SHRINK) IF U HAVE, TO REPLACE PUSH CONNECTOR.hitting the casing usually breaks the the guts inside. failing this replace brushes inside and clean
