Old 02-23-2009, 09:51 PM
zuke448 zuke448 is offline
1995 lumi ls problems
Okay here is the deal. went down the road today like 1 mile ran into the gas station came back out tried to start my car and nothing but cranking. let it sit like 2 minutes boom started right up. It had done it like three weeks ago but we have had lots of ice here and I thought that when it started to melt that I got some gas with water in it. Ran some heet no big deal ran fine till today Here is some additional info in the past 6 mos. It has had plugs, wires, fuel filter, new air cleaner. car has 85k on it and runs just fine besides the whole thing today
Old 02-24-2009, 07:45 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 1995 lumi ls problems
Can you hear the fuel pump run for 2 seconds when you turn the key to "run" when this happens?
Has fuel pump ever been replaced?
Next time it happens (and it probably will) listen for fuel pump- or better yet - put a fuel pressure gage on it- see if your F/P is working.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-26-2009, 05:28 PM
I really can't tell with the pump at all it is really quiet. But it did it again today ran an errand forgot some paper work came back shut the car off for maybe a min wouldn't start gave it like t min boom started right up. This makes no sense to me at all.
Old 02-26-2009, 07:31 PM
twistedtech twistedtech is offline
The fuel pump is great place to start. Has about the right miles on it for that to start. Your going to have to figure a way out to hear it or as stated, actually see if it is working.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 03-01-2009, 01:45 PM
Yeah the fuel pump is working. I had someone power on the car when I was laying by the gas tank. I think that it might be the crank trigger. It died the other day then ran really rough for 20-25 seconds then just fine.
Old 03-02-2009, 12:52 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
When it was running rough, did it put out black smoke from the exhaust?
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 03-02-2009, 01:29 AM
saxonmor saxonmor is offline
My '95 Lumina did this some years back. Pull the cover off the fuse panel on the right side of the dash (you can see it when you open the passenger door.) Make sure all the fuses are tightly in place. If worse comes to worse, replace the fuse for the ignition circuit, which is what I did. Haven't had a problem since.
Old 03-08-2009, 11:39 PM
"When it was running rough, did it put out black smoke from the exhaust"
Nope nothin just wouldn't start
