Old 02-23-2009, 03:52 PM
stick64's Avatar
stick64 stick64 is offline
Spark Plugs for S10 4.3
What is the latest and greatest with spark plugs ? Is there a clear cut "best" ? thx
Old 02-23-2009, 05:13 PM
duke350 duke350 is offline
Re: Spark Plugs for S10 4.3
Go with the best grade delco plugs you can get for your engine. In my opinion, at least.
Old 02-23-2009, 07:41 PM
old_master's Avatar
Advisor/Moderator
I agree, AC Delco only in the 4.3L engines.
You have to know how it works,
to figure out why it doesn't.
Old 02-24-2009, 08:26 PM
WisBlazer05 WisBlazer05 is offline
Send a message via AIM to WisBlazer05 Send a message via Yahoo to WisBlazer05
I have a 1998 S10 Blazer, there are 2 plugs I can not seem to get to. Is there a trick to this?
Old 02-25-2009, 04:00 PM
old_master's Avatar
Advisor/Moderator
All plugs except #3 can be accessed by raising the front wheels off the ground and working through the wheel wells. To access #3, disconnect the steering shaft from the steering gear and move the shaft aside. Don't allow the steering shaft to turn while disconnected from the steering gear or damage to the clock-spring will occur. This thread might help: http://www.automotiveforums.com/vbul...d.php?t=503231
Old 02-25-2009, 04:15 PM
b1lk1 b1lk1 is offline
At the very least make sure to use platinum plugs. I put a set of NGK's in and they are working great!
Old 02-26-2009, 09:01 AM
ken_man_1 ken_man_1 is offline
Thumbs up Re: Spark Plugs for S10 4.3
I bought a spark plug socket that has the swivel built into it and I use that with no problems. Might be a thought instead of removing steering stuff.
