Old 02-23-2009, 03:14 PM
Allegretto's Avatar
Allegretto Allegretto is offline
Send a message via Yahoo to Allegretto
Question harmonic balancer
its the one and only! my harmonic balancer is going to heck and its making oher things on my car act bad. the battery needle is all over the place and the alternator is screaming bloody murder and theres this loud clanking sound like the rods are knocking but i know theyre not cuz u i had it checked. i just need some tips and advice on replacing it i bought a new balancer i just dont know how to put it in. if u got any suggestions or tips send me a email at [email protected] and thanks
Old 02-23-2009, 05:21 PM
Jrs3800 Jrs3800 is offline
Re: harmonic balancer
You will have to have a Puller ( Prefer a 3300-3800 Harmonic Balancer Puller )
You will have to remove the Crank Bolt.. Takes a lot of force...
The Balancer is a Press fit of sorts and will not just slip off, thats where the Puller comes in..
Might also be a good time to invest in a new Crank sensor as well..
Old 02-23-2009, 08:39 PM
big white bufflo big white bufflo is offline
rent a puller from auto zone or go to sears remove pass side tire remove splash sheild you need impact wrench or use a braker bar and try hitting it with a hammer to brake the bolt lose use puller to pull it off your done put it back together but it up to you if you want to replace crank sensor mine had 145000 before it went bad
Old 02-25-2009, 06:52 AM
86aaz 86aaz is offline
Take a look at this website:
http://mykidz.net/GTP/CrankPosSensor.shtml
I did this in an Autozone parking lot and it was an absolute nightmare (EVERYBODY has an opinion!). Other than the people, the thing that held me up was that the puller kit I rented there (even the one I later bought) did not have the correct bolts for the harmonic balancer. Before you take anything apart, go buy 3 - 1/4" X 3" 28 NF (National Fine) bolts. Autozone didn't carry these at all! So, go to Lowe's or Home Depot and get a few of those.
Good luck!
Old 02-25-2009, 01:00 PM
usedranger usedranger is offline
Nice pictures. This should help some folks out more than the generic instructions in a Chilton's.
Old 02-25-2009, 02:27 PM
imidazol97 imidazol97 is offline
AF -Advisor
Great writeup. And the pictures will be a great help to others. Thanks for sharing.
Old 02-25-2009, 02:41 PM
Yes, it is a good writeup. The starter trick helped me get the harmonic balancer bolt off without too much trouble.
Old 03-02-2009, 07:51 PM
Allegretto's Avatar
om my god thanks a lot you guys ROCK
