Old 03-25-2003, 09:32 PM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
Question Piston to Valve clearance and CR questions.
I was wondering if there were any ways I could figure out what my piston to valve clearance is without claying the engine... Im using Endyn 11.16:1 pistons, other than decking/surfacing the head and block im pretty sure everything is stock (The Dohc ZC came from japan, so who knows) I will be using a 0.032(mm?) SCE copper head gasket from a D16A1. Im not sure what the stock ones are... I think my machinist told me I wanted a 0.030 one!? I will be using WEB reground cams (not hard welded) and (Hopefully) larry's SS valves and D16A1 rocker arms. Oh, it also has Eagle rods, I dont think that should make a diff. Anyone know what the piston to vlave clearance woulb be? Or could I calculate what it would be IF I knew what the stock highth of the block was? Also, anyone know what my compression would be?
Thanks, seth.
Valve Clearance and Engine Knock blk95lumina Camry/Camry Hybrid/Vista 8 09-17-2009 03:08 PM
Piston-Valve clearance problems? gsr916 Integra 0 05-17-2005 11:36 PM
4G63 pistons, rings, valves, valve springs and retainers 91 Eclipse Off-Topic 1 03-10-2005 08:38 PM
piston clearance and swap questions? Red B16A JDM Motor & Parts info/chat 0 01-31-2005 07:05 PM
Piston to Valve Clearance vpap1 Camaro Discussions 3 07-22-2004 05:56 PM
