| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
ok. I am working on a 94 cavalier. The battery if left connected will be stone dead over night. If I charge it over night with the battery disconnected from the car it holds a charge just fine. As long as I unhook it from the car it holds a charge.
Now.... the clock on the radio never goes out. is it supposed too? I am suspecting the ignition switch. anybody had any experience with this problem and/or replaced the ignition switch? Thanks a bzillion.
94 Safari 203000 miles 94 metro 310000 miles |
Re: 94 Cavalier, good battery, goes dead, clock stay on
The clock should go out, but that alone wouldn't kill a good battery over night.
Connect an ammeter (preferably a clamp-on meter just because it's easier) on one of the battery cables. It should read .05A or less. When you find it's higher, pull the fuses one at a time until the reading drops to an acceptable level. Remember to remove any light bulbs that need to be on while testing (under hood, dome, glovebox, or whatever
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
I connected my ammeter between the negative cable and post. with the radio fuse in I am seeing .25 amps. with the fuse out it's down to .01 amp. That doesn't seem like enough current to kill a battery over night. I think I may have a bad battery after all. I'm going to put it in my van for a couple days to see.
0.250 amps (250 milliamps) is too much-- manufacturer's recommendation is no more than 50 ma-- A single relay will draw 150 ma and can cause a car not to start overnight-(been there, done that)- yours is more than that- so therein lies your problem- something on that circuit is on all the time-- have you added aftermarket equipment- like a new radio, some remote keyless entry modules, or a remote starter? how about lights, or charger connections- anything changed since this happened? Has anyone worked on it since this started?
Just some things to ponder- other than that, you need to start seperating wires on that circuit to finally find the draw. A good wiring diagram is essential.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
