| Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications. |
I need a quick run down for an audio install...
Hey guys. I need some help. I am installing an enclosure and an amp for my girlfriend. I am sure she has all the wiring. Now explain something to me real quick.
I know I have to run the power cable from the positive terminal to a fuse or fuse box. Now which fuse do I run it to, where at on the fuse box do I connect it, or should the cable already have a fuse on it? After that I need to run it through the firewall and into the cab. From there I have to get it to the trunk. My best guess would be to run it under the carpet, correct? How do I remove that? Does it just pop up and get pushed back down or what? Once I get it in the trunk I am golden except I need to ground it. Some say ground it up front or you can ground in the trunk. Totally clueless on this. Then the RCA cables. Same as power cable except instead of going to the battery I take it behind the dash and plug it into the stereo. What am I missing? Thanks in advance guys. |
Re: I need a quick run down for an audio install...
the trim pieces around the carpet just pop out, run the cables under there. You'll almost certainly want to run a ground wire back to the battery. The body ground cable is very small (I think 10 gauge), so it really isn't suitable for any significant amperage. Also, don't go overboard on the power wire to the amp. Take a look at the wire coming off the alternator... except for enlarging it one or two sizes for the distance it travels, don't go bigger than the B+ wire on the alt. If your amp actually consumes that much power, install a high amperage alternator or you'll burn the stock one up in no time
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
how many watts RMS is the amp? chances are amp will require a power wire larger than what ur fuse box could accept anyway. it will probably be around 8 gauge. as for the ground wire, u could get away with drilling into some solid sheet metal or if u can get to the frame as long as u have a good connection with bare metal. i have 4 gauge with 3 amps and over 1000 watts rms going thru my sheet metal with no problems. and ur gunna need a remote wire to turn the amp on. do u have an after market radio or stock?
