2000 LS V8 - Heater blows cold
I've read through a few other threads on this topic and am still not sure what's going on.
Here's my story though: 3 months ago I had to replace the engine in my car (did it all myself) because of a broken timing chain that broke a few valves and put dents in a piston. After putting it in the heat worked fine after a few months.. fast forward about 2 months and one day it got a little low on water/started to over heat (maybe 1/8" over "normal" temperature on the gauge). I make it to work, wait for it to cool off..add more water and it hasn't overheated since. Unfortunately the heat also hasn't worked since. There are no error codes in the auto diagnostics on the DATC and the water lines going to the cabin are hot (although them being right beside the engine makes it hard to tell for sure--but I think they're hot). Today I tried leaving the ignition in the on position w/car turned off in hopes that the water pump in the cabin would get things moving but it still blows cold. Any ideas?? I was thinking air at first but after a month I figured I'd at least get a LITTLE water flowing by now if that was the problem. |
Re: 2000 LS V8 - Heater blows cold
I'd run through the process for bleeding the air from the cooling system before getting too excited. I think the process has been posted on here a time or two.
-Rod |
Will do.
Nevermind..found it. Here it is for anyone looking:
http://www.carsonparris.com/ls/bleedcoolingsystem.pdf Last edited by schpenxel; 02-23-2009 at 10:14 AM. Reason: LINK |
| The Following User Says Thank You to schpenxel For This Useful Post: | ||
parker076 (07-15-2012)
Well, during my lunch break I decided to play with the bleed screws a little.. I loosened the one for the heater that is beside the radiator reservoir on the drivers side of the engine compartment. Antifreeze immediately came out and I saw no air. I didn't want to get antifreeze all over the work parking lot so I closed the valve before much came out.
When I get home I'll let it run out a lot more to be sure all air is out..but there is definitely pressure pushing antifreeze out from that bleed screw and from what I've seen so far no air is in that part of the system. Any thoughts? |
Last update
![]() Dug down to the auxiliary pump tonight and there was infinite resistance between the terminals. That leads me to believe the pump is bad. Will replace and report back--I'm guessing the short run without water/overheated water fried it. It has 200K miles on it so I guess it was about that time
Interesting find. Please report back with results.
-Rod |
Does anyone know where I can buy this pump from?? I can't find one in any of the online catalogs or eBay...
