Old 02-22-2009, 01:01 PM
stroked84montess stroked84montess is offline
95 blazer fuel problems.
I just bought a 95 blazer 4.3 4x4. 140k on it. Its got a rough idle and sputters and pops untill about 2500 then clears out. it sat for a yr and a half. put new fitler on it and helped a little bit and put seafoam in it and that helped quite abit also. Its got a lean pop but pours out black smoke. help? The check engine light is on. How do u check that what scanner do i use. Because the OBDII just showed a Error when trying to read it. HELP!
Old 02-22-2009, 08:11 PM
tempfixit tempfixit is offline
Re: 95 blazer fuel problems.
This site should help you with getting codes:
http://www.autozone.com/shopping/rep...00c152800bfd9f
Check you fuel pressure with a gauge to start with and post codes.
