factory remote not working
my 1999 jeep grand laredo remote is not working i change the batteries it worked for about 4 days and again u press the bottons and nothing happens is it cause its cold or what?
Re: factory remote not working
First step is to check both batteries (Panasonic model CR2016 or equivalent) voltage with a volt meter, they're rated at 1.5 v each. If they check ok make sure they are both polarity oriented correctly and making good contact with the remote.
If all of above checks out it's possible the remote needs reprogramming. Correction. The remote batteries are 3.0 volts each. Last edited by Bob D.; 02-27-2009 at 07:48 AM. |
I did that already I went to pepboys and got some energizers with the same # as the panasonics that were in there originally. so who can reprogram it?
Any Jeep/Chrysler dealership.
it started working again by it's self go figure
Factory Remotes can be trickey, Do you have a hood switch on your car? If the hood it up it should NOT let the car start. Also, one lead monitors the brake lights. If the brake is on it won't start. If it's with the remote & you step on the brake the car shoudl quit. Also, if started with the remote pressing on the GAS & revving the engine will also kill the engine.
Concord, NH. 05 Jeep Grand Chrokee Laredo |
I found on 2 of mine that after a while the micro switches come loose from the circuit board. I have had to resolder them a couple of times already. 4 solder connections on each switch.
1995 Jeep Gtrand Cherokee 4.0L auto K&N filter cat back exhaust 1976 Jeep CJ-7 4.2L 3 speed 1990 F-150 4X4 5.0l 5 speed 1990 GMC K-2500 4X4 5.7L auto 1993 F-250 4X4 7.3L Banks straight pipe 1979 F-150 4X2 300-6 4 speed 4bbl dual exhaust 1941 Allis Chalmers C 1945 Allis Chalmers C wide front |
