Help a female out
My 87 2.8 5spd was finally fixed after wks of vaccum lines,spark plug cables, and much more. It ran well. Then after letting it warm up for 15 min, i took off ran good thru 1st, 2nd, 3rd, then when i put it in 4th it started back fireing/ bucking. i put it back in 3rd ran perfect put it back in 4th back fired about 5 times and shut done. this was while goin around 50mph. I pushed it to a driveway "who said it was a heavy car?" tried to start it and it was fireing and turning over for a couple of sec but when i tried giving it gas it dies. It also is back fireing while it was trying. I smelled ALOT of gas also. I was thinking it was the timing chain but then got to thinking it was the distributer. What do the PRO's have to say???
Re: Help a female out
If you snapped or jumped the timing chain the engine would have died instantly.
While in theroy it's possible the distributor jumped out of time, it's not very likely. There is one thing, though. Was the spark timing adjusted recently? If the distributor hold down isn't tight enough, engine vibration can back out the bolt and cause the distributor body to rotate freely. This is certainly a resonable explination of how a engine could begin backfiring under load, then get worse, then eventually die. If you can grab the distributor body/cap and rotate it in the block, that indicates that's just what happened. Besides spark at the wrong time, other causes of backfiring include a stuck intake valve, typically a result of a bent pushrod. High carbon buildup on the piston tops, poor quality gasoline,or gasoline with too much ethenol blended in (depending on the engine's static compression ratio) can lead to a similar condition known as preignition, or "spark knock" as it's often called. Spark knock is extremly destructive and easily cracks, or even burns holes in piston tops.
Wanted to buy: 86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply. 74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!! 3Rd gen F body floor pans/camaro door skin (L) Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Last edited by Ragtop_Renegade; 02-23-2009 at 10:10 PM. Reason: I shouldn't type when I'm tired! |
