Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-22-2009, 02:06 AM
scott9911 scott9911 is offline
Send a message via Yahoo to scott9911
Exclamation 95 Camaro Z28 auto tranny problems
I just traded for a 1995 Z28 a couple weeks ago and today I tried getting on it hard to see how it would shift and it went way past red line and did not shift at all.
I did this from a dead stop.
I let off the gas and it shifted.
I tried 2 more times and it did the same thing both times.
If I drive it normally it shifts fine but kinda hard.
I have noticed that if the car has been running and is warmed up it shifts better.
If I start off while it's cold it gets up to 3500 RPMs before it shifts from 1st to 2nd and then it will go to 4000 or more and I have to let off the gas to get it to shift from 2nd to 3rd.
Any idea's what might be the problem??
The guy I got it off of said they had the tranmission replaced but I don't know how long ago that was.
Old 02-22-2009, 04:18 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 95 Camaro Z28 auto tranny problems
i would try a fluid and filter change first and see if that helps. if not, something internal may be bad or set up improperly. trannys are a pretty complex item and the most insignificant little thing can cause a world of problems.
Old 02-23-2009, 09:14 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Could be a improperly adjusted TV cable.
Old 02-23-2009, 11:45 AM
Genopsyde's Avatar
The President
i was thinking that too, but doesn't the 95 have an electronic trans?
