Go Back   Automotive Forums Car Chat > Ford > Festiva
Old 02-21-2009, 02:10 PM
car questioner car questioner is offline
Different tire sizes
What is the difference between 155/80R12 tires versus 155/76R12 tires?
I had a tire with a bubble and I had no other choice than to buy the 155/76 tires. What problems may I run into with this decision?
Old 02-21-2009, 06:11 PM
rhandwor rhandwor is offline
Re: Different tire sizes
The diameter is slightly different. The speedometer may not read correctly. Make sure both tires are on the same axle.
Old 02-21-2009, 09:19 PM
I only purchased 1 tire.
Old 02-21-2009, 10:05 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
then buy another one
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 02-21-2009, 10:25 PM
I cannot buy another 1 because I was lucky to get the 1.
Old 02-22-2009, 05:06 AM
At least don't run it on a drive axle.
Old 03-03-2009, 06:47 PM
denisond3 denisond3 is offline
Those tires sizes are so close together that you can expect it to work fine. The new tire is maybe an inch shorter in height - so that corner of the car will be no more than half an inch closer to the ground. If you were going to try and go around corners at high speed, (at the limit of adhesion), the tire mismatch might affect handing.
Old 03-15-2009, 09:22 PM
Thanks for the help.
Old 09-07-2009, 06:13 PM
vanbc vanbc is offline
up here where I live if you have different size tires and get into an accident, insurance won't cover you.
