1999 expedition eb air susp problem
One of my rear airbags inflates higher then the other causing the truck to lean a little i deflated the system and turned it back on the air bags inflated together until the last click cycle then the right side keeps inflating causing the lean then the ck susp light comes on no leaks the front is fine what could this be. so what did was deflated the system and then reinflate until i think its high enough then turn system off i would like to fix this problem.
Thanks! |
Re: 1999 expedition eb air susp problem
I also have a 99 with the same problem. It all inflates fine except the rear drivers. I cant find any leaks or any problem with compresor. It clicks on like its supose to till the check suspension light comes on. Let me know if you find anything out.
I also have a 99 with the same problem. It all inflates fine except the rear drivers. I cant find any leaks or any problem with compresor. It clicks on like its supose to till the check suspension light comes on. Let me know if you find anything out.[/quote]
hey found ur thread... 02/18/11 ..i have eb 97 expedition same problem.. leaning on drivers side.. did u ever find out the cause /?? pls e-mail me thx .. [email protected]
