Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-21-2009, 12:45 AM
rockwood84 rockwood84 is offline
ambient air sensor on a '04 location
my outside air quit reading on the dic .everything on the dic is still being read. i looked around the grill in front of the condensor and found a black plastic thing on a brace. didn't mess with it too much ,as might be airbag sensor.mine has auto temp air/heat and was told it wouldn't work correctly without the ambient temp.anyone else have problem with the ambient air sensor? thanks
Old 02-22-2009, 06:12 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: ambient air sensor on a '04 location
If the ambient air temp sensor is located in the same location in the 2004 as it was in the 2002, it should be on the right hand side of the engine compartment near the front. The connector will be mostly round with two wires to it, a dark blue/white wire and a dark blue/yellow wire.
-Rod
Old 02-22-2009, 11:22 PM
ok shorod i'll check there and see if the connector is just loose.
