Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-20-2009, 11:01 PM
Cat Fuzz Cat Fuzz is offline
I almost sold my Rodeo, continued....
Now I have TWO rodeos! I picked up a '99 LS with perfect interior and leather seats for less than $1K. It has 20" custom wheels with low profile tires. Not crazy about them but I think I can find some tires to go on that look more like they go on a 4x4 instead of a rice-mobile. Or, I can probably sell the wheels for enough to buy a good used set of wheels and tires.
The only hitch is, it has a rod knock. So, out comes the motor. I think I'll go for the quick fix and find a good used motor instead of rebuilding. I'll get some pics tomorrow.
Old 02-21-2009, 12:08 AM
Ramblin Fever Ramblin Fever is offline
Re: I almost sold my Rodeo, continued....
Sweet...congrat's!
Post pics when you can.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 02-21-2009, 09:21 AM
Florsuzo Florsuzo is offline
How does one know it's rod knock and not the hydraulic tensioner? Is there a fool proof way of knowing (just curious)?
1997 Passport EX, 3.2L SOHC, automatic, 4WD, 131k.
Old 02-21-2009, 10:28 AM
Experience. I'm sure it's not the tensioner but I will pull the timing cover off before pulling the motor. The knock is to loud and it's constant. Tensioner noise is usually intermittent.
Old 02-21-2009, 07:57 PM
FL 3.2L FL 3.2L is offline
I figured you had the tensioner angle covered, but I'm still curious to see what you find. It'd be criminal, grand theft auto, if you only needed a timing belt job.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 02-21-2009, 08:17 PM
It's not the tensioner. I was hoping it was. O well.
Cleaned it out today. Leather seats are perfect. Other than the engine, it's mechanically sound. Good brakes, looks like new rotors recently. CV boots are all good. Steering linkage is tight. It is stuck in four wheel drive but that should be an easy fix. Came with a nice Pioneer CD player. I'm hoping to have the engine pulled next weekend. Can't wait to start driving it.
Old 02-23-2009, 10:23 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
How's the tranny look?
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 02-23-2009, 10:35 PM
Transmission seems ok. I've only had it running for a total of a few seconds because I don't want to do anymore damage to the crank or rods. I'm probably going to pull the engine and crank and if the rods spec out ok, I'll have the crank welded and re-ground. If the rods are messed up, I'll have to pull the heads and have them re-conned.
