Old 02-20-2009, 08:09 PM
hiergehts's Avatar
hiergehts hiergehts is offline
Question Tires needed - can you help?
Awhile back I put up a thread searching for a set of suitable small & narrow tires for a 1980's European Ford Escort project that I started. Because of a lack of these it's been stalled but I finally found something suitable, the stock tires bagged in AMT's recent reissue of the Opel GT, kit #31226.
Does anyone have a set of 4 that they'd be willing to sell or trade? I'm only looking for the tires, not an Opel GT kit..
TIA
Hiergehts
Old 02-20-2009, 09:45 PM
jla's Avatar
jla jla is offline
Re: Tires needed - can you help?
Don't have the tires, but you should check out the old Monogram Porsche 904 kits, I see those all the time on ebay if you're willing to pick up a complete kit.
Old 02-21-2009, 01:18 PM
hiergehts's Avatar
I already have the wheels I plan to use on the Escort and had checked the Monogram 904 tires. Unfortunately, their ID is too large for my wheels.
Thanks,
Hiergehts
Old 02-21-2009, 03:02 PM
ratpackv8sonly ratpackv8sonly is offline
I can make you a set of them out of resin if you would like. Just pay me for the cost of the materials that it would take to make them and shipping. I already have the kit.
Old 02-21-2009, 05:52 PM
hiergehts's Avatar
Since you know their size already, what do you figure the material costs would be here?
BTW - Is this using standard tan resin or ?
Thanks,
Hiergehts
Old 02-22-2009, 06:00 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
I think i have some. what is the inside dia. of the tires you need?
SCCA 7, The lost Z
Old 02-22-2009, 09:03 PM
hiergehts's Avatar
That would be great. The dimensions on the ones I checked are:
ID: 0.52" (13mm), OD: 0.96" (24.5mm) & Width: 0.31" (8mm)
FWIW: They also had "BF Goodrich" & "The Advantage" on one side.
If you had something with a slightly larger ID (say 0.59"/15mm) but the same dimensions otherwise, that would be perfect. As they are now, I'll still have to modify these as the wheels I'm using have a 15.5mm OD.
Thanks,
Hiergehts
Old 02-23-2009, 12:10 AM
Ferrari TR's Avatar
Not A Hoarder!
Well i found a bunch of Michelin x's about 20% bigger than the ones you're looking for.
i wish you luck.
SCCA 7, The lost Z
Old 02-23-2009, 08:38 AM
hiergehts's Avatar
i wish you luck.
Yeah, that's not going to work. Thanks for your input though.
Hiergehts
Old 02-23-2009, 06:50 PM
I can make them out of tan, white, or black resin. Would just charge you for the mold to make them ($10.00 U.S.) if I just used one of these three. If you wanted to have them in soft black rubber then I would have to check on the cost for the rubber.
Old 02-24-2009, 01:05 AM
hiergehts's Avatar
Black resin would be great as I have to enlarge the inner opening of the tires to fit the wheels I'm using anyway. Would it possible to get 2 sets (8 tires)? That way I have an extra set 'just in case'..
I knew a local modeler friend (who sadly died of a heart attack a few years back) who did a lot of resin casting for himself and friends. He used a pressurized chamber, getting excellent results with most parts being completely bubble free. Most of what he did was for aircraft models.
Thanks again,
Hiergehts
Old 02-27-2009, 07:26 PM
Sure thats fine. Like I said Just pay for the mold and I will send you two sets in black resin. PM me with your info.
Old 02-27-2009, 09:50 PM
hiergehts's Avatar
PM sent..
Thanks,
Hiergehts
