Old 02-20-2009, 07:42 PM
Av8torfix Av8torfix is offline
2000 SE Brake Problem
Brake problem...I'm not completely sure how the ABS system works, But I'm learning.
The problem I have is that I am getting no brake fluid to the rear brakes.
Master Cyl. checks OK and I have fluid to the ABS module (2 lines going in 4 coming out).
What would cause me to have no fluid to the rear brakes? Front brakes are fine.
I'm assuming that the front would work even if the module has failed. Is that a correct statement?
I Had the system checked and it was loaded with codes. I was told the module would be about 6 hundred dollars. Ouch
Old 02-21-2009, 09:44 AM
tommytomt tommytomt is offline
I am having the same prublem did you get an answer
having the same problem but have not got an answer on it my self
Old 02-21-2009, 10:17 AM
3100 3100 is offline
Banned
Re: 2000 SE Brake Problem
what are the codes?
