Old 02-20-2009, 10:15 AM
bcb07 bcb07 is offline
'97 Z24 Cavalier Losing Coolant/Overheating
Hi!
I have a '97 Z24 Cavalier at 193,000 miles. I am consistently losing coolant and overheating. There are no visible leaks. I checked the oil, and did not see any coolant mixed in with the oil. I haven't seen any liquid coming from the tailpipe. When the car is started, you can smell the coolant through the air vents some, and can smell it under the hood. Nothing appears wet or anything. I checked the floorboards, and they were not wet. There is no steam blowing out of the vents. I have heard bubbling sounds sometimes when I shut off the that sounds like it was coming the passenger side dash. Any ideas on what this could be?
Old 05-29-2009, 12:22 PM
Tiskie Tiskie is offline
Re: '97 Z24 Cavalier Losing Coolant/Overheating
Check the heater core, mine also leaked through some kind of defective sensor somewhere...
Old 05-31-2009, 03:01 PM
Jmrec100's Avatar
Jmrec100 Jmrec100 is offline
Yes, check the heater core. Mine on my 1999 sprung a leak. It ended up dripping down and looked like it came from the overflow. It was the heater core dripping into a pan. Check the heater core. And be warned, Its a %$@! to replace.
