hi i have a 91 camaro and i put a aftermarket tach in but on the distributer cap the a plug wit a brown wire white wire black wire and purple wire and on the other side theres another plug with a thick red one and a white one soo which one should i use?
Re: tach wire
On the cap itself where the 2 wires connect it should say "Bat" (red wire) and "TACH" (white)
If not the BAT wire is the power supply and closest to the front of the motor where as the TACH wire is the one closest to the rear. Do not splice into the 4 wire harness! |
Re: tach wire
the 91 has a divorced coil hei ignition. there is no BAT or TACH hookups on the cap. you need to splice into the white wire that goes to the igniton coil
Re: tach wire
Doh!
![]() I feel so blonde today.
Re: tach wire
it's ok. it happens to all of us.
Re: tach wire
It's the buttocks you have shaking in your sig
Re: tach wire
tis a lovely view isn't it.
