Old 02-19-2009, 08:27 PM
helicopter23 helicopter23 is offline
DIC Problem
The DIC lights in my 97 Grand Prix GT (104k) sometimes are brighter than other times when I am driving. However tonight right before I was about to turn off my car, the DIC center lights started blinking randomly rapidly. This was the first time they ever started to blink like that. When I restarted my car the DIC was fine, anyone know why they were blinking an hour earlier?
Old 02-20-2009, 07:52 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: DIC Problem
Has the problem reoccurred?
Timeslip 08/12/06
AF Community Guidelines
Old 02-20-2009, 01:44 PM
Re: DIC Problem
No, it only did it the one time. It didn't do it yesterday when I drove it.
The dic brightness is changing a few times per trip from medium to very bright?
Old 02-20-2009, 07:26 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: DIC Problem
is it possibly a bad connection at one of the bulbs? Mine was doing that too, and when I would tap the top of my dash, the bulbs would all light and come on as normal.
Replacement of all the bulbs cured my problem.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-20-2009, 09:03 PM
CrazyHorst CrazyHorst is offline
Re: DIC Problem
Might also be a good time to check the B+ terminal on the battery to ensure good conductivity/no corrosion.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 02-21-2009, 11:17 AM
BNaylor's Avatar
Re: DIC Problem
Do you still have your original ignition switch? A lot of times when the DIC starts acting up that may be the first signs of an ignition switch going bad. The 12 volt supply is being affected due to carbon buildup on the electrical contacts. The carbon acts like a resistor or causes arcing. As it gets worse over time you may see other accessories start acting up like the headlights, climate control, cruise control, etc.
I had the same issue about 4 years ago. I remove the ignition switch, took it apart and cleaned the contacts. The DIC has not acted up since.
Timeslip 08/12/06
