Old 02-19-2009, 05:09 PM
diesel642 diesel642 is offline
04 Cav. AC Max in/outside air door actuator
I need to know where the actuator is for AC Max in/outside air door. I'm not sure how to get to it. I would appreciate any help I can get, thanks.
Old 02-19-2009, 06:00 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 04 Cav. AC Max in/outside air door actuator
It's on top of HVAC module, under dash behind glove box- may be tough to get to.. is it stuck? whyy do you need to get to it?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-19-2009, 06:15 PM
When it gets to the end of opening the recirculation door it keeps running and clicking very annoying. Can I get to it by removing the dash?
Old 02-19-2009, 08:04 PM
brcidd's Avatar
Yes- it is evidently stripped out-- The service manual says it is a dash pull- I guess if it were mine, I'd be sure it was in outside air and then either unplug it, or cut the wires- until I had reason to pull out the dash..and the HVAC module.
If it is stuck in recirc- you run the chance of severe window fogging when temps and humidity are just right...seen it happen where no amount of heat to the windshield will defog the glass when recirc door is stuck on recirc air....
'99 GMC Yukon
Old 02-19-2009, 08:20 PM
Does the HVAC module need to come out to replace the recirculation door actuator?
Old 02-19-2009, 08:52 PM
brcidd's Avatar
Yes- First steps are to evac the a/c refrigerant- unhook all lines to HVac module, and do the dash pull.....then pul the module out just to get at the actuator...
'99 GMC Yukon
Old 02-19-2009, 09:01 PM
Thanks for saving me a bunch of work, I think I will unplug it.
Old 10-05-2009, 11:42 AM
sloechli sloechli is offline
I have the same problem in my 2005 Cavalier, loud clicking unless in recirculate, where is the connection that I can remove, any diagrams you can point me to? What is the exact part name, I called dealership and was having trouble identifying the part.
Old 12-16-2009, 02:53 PM
bigcjv bigcjv is offline
Did you ever get any further information. I have the same problem on my 2005 Cavalier and would like to disconnect it.
Old 01-04-2010, 11:03 AM
Did you ever get any further information on your 2005 cavalier re-circ air door clicking problem ? I have the same issue with my 2005 cavalier and would like to diconnect it, but don't know where to disconnect.
Old 01-26-2012, 07:27 PM
superdrew28 superdrew28 is offline
I have the same problem, where can I disconnect the actuator? Please its so annoying!
