Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 02-19-2009, 04:48 PM
tbewley tbewley is offline
Radio 98 Sable
sometimes the radio wont come on and sometimes does but I never lose memory/ any ideals
Old 02-20-2009, 01:26 AM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Re: Radio 98 Sable
There are 2 Positive wires that go into the radio to turn it on and 2 negitive (antenna grounds the radio and usually there is a black wire attached to radio to ground)
1 Positive - 12 volt positive always live straight to battery (for memory)
1 Positive - when you turn the key to Acc or run comes live to turn on radio.
Is the radio the only thing that doesnt turn on? if there are other things not working along with radio i would think your ign. switch is bad. if the radio is the only thing i would think the radio may be bad.
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
Old 02-28-2009, 09:00 PM
thisnametooktolong thisnametooktolong is offline
Re: Radio 98 Sable
I have had the same problem with my 96 (it’s the same darn car) You can remove the radio using 4 nails in the 4 holes in the face plate. This releases 4 springs and the entire unit pops out. I cleaned the plugs and re installed the radio. It has worked fine for 18 months and I live on a dirt road with 2 kids.
Old 03-01-2009, 10:03 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Radio 98 Sable
Does it come off and on when moving the shifter from park or neutral into gear? If it does, replace the transmission range sensor on the transaxle.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
