Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-19-2009, 02:48 PM
03gmc 03gmc is offline
Coolant Leak
I have a 2003 2500HD with 6.0 Lt and my low coolant indicator came on today, looks like it's leaking from the right side of the engine somewhere(looking from the bottom) can't see anything from the top. Just wondering if anyone has had a leak similar to this.
Thanks
Old 02-19-2009, 03:13 PM
duke350 duke350 is offline
Re: Coolant Leak
Have in the neighborhood of 125-140k miles on it? First thing I would check would be the intake manifold gasket.
Old 02-19-2009, 03:19 PM
Re: Coolant Leak
No... It's got 50,000 klms, i've been reading about water pump gaskets maybe i'll check that?
Old 02-19-2009, 06:55 PM
Re: Coolant Leak
If its leaking externally you should be able to track it down. Might have to remove a panel or two, or use a mirror, but you should be able to find it. The areas I would suspect would be water pump, intake or hoses. Is it a constant leak, or only/worse when warm, only/worse when cold?
Old 02-19-2009, 09:31 PM
2000CAYukon 2000CAYukon is offline
Re: Coolant Leak
Coolant does not run through the intake on Gen III engines.
//2000CAYukon
Old 03-03-2009, 02:06 PM
Re: Coolant Leak
Finally got a chance to look at the truck (holidays). It is the water pump gasket, next question how hard is it replace the gasket?
Looks like there is 6 ? bolts. What else needs to be taken off. Any help before i do this would be great, looks like a Saturday morning job.
Thanks
Old 03-03-2009, 03:33 PM
Re: Coolant Leak
My labor guide puts the water pump at 1.9 - 2.3 hours.
Make sure it is the gasket and not the weep hole.
There is a how to listed at autozone, with pictures. http://www.autozone.com/addVehicleId...249073#hd1-1-2
Old 03-08-2009, 04:26 PM
Re: Coolant Leak
The job was easy to do took about 2.5 hrs, these gaskets must be a common problem. I had to go to 3 parts stores before io got a set.
Thanks to those who replied.
