Old 02-19-2009, 11:47 AM
BlueGTP BlueGTP is offline
2002 GTP EngineThermo/Fuel Filter
I recently took in my 2002 Grand Prix GTP in the dealer b/c my "service engine" light came on, they checked it out & said I needed a new Engine Thermostat ($250parts/labor), Fuel Filter & flushing of my fuel injectors ($185parts/labor), I'm trying to see if thier is an alternative way I can get this done cheaper, or if anyone happens to know the actual GM part no. or if a differnt maker would be good enough.
The noted the scan code to be "P0128, P0300 trace codes to Low Engine Temperature, random misfire needs engine thermostate. Needs fuel filter and fuel injectors serviced"
My mileage is 79,429
Old 02-19-2009, 12:00 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: 2002 GTP EngineThermo/FuelFilter
I can't speak for the latter but a thermostat is less than 10 bucks and it takes me only 15 minutes to change mine out. Very simple on these cars.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 02-19-2009, 12:03 PM
Can I use any type of maker or should it be a GM part?
Old 02-19-2009, 12:11 PM
For a thermostat, I use AC Delco or aftermarket Stant Superstat brand. I've also used whatever the local auto parts store have in stock and I've haven't had any problems. I think there's directions in the "Tips and Maintenance" section of this forum.
4 door sedan
No Mods
Old 02-19-2009, 01:17 PM
doctorhrdware doctorhrdware is offline
The fuel filter you can do yourself also, it is not that hard to do. For the injector cleaning I use Seafoam or I use Lucas injector cleaner.
Old 02-19-2009, 02:41 PM
$250.00 to replace a thermostat is highway robbery unless there's something we're missing here.
4 door sedan
No Mods
Old 02-19-2009, 03:20 PM
CrazyHorst CrazyHorst is offline
I would have to agree. 10mm socket for removing the water outlet. 7mm box wrench and a few paper towels for bleeding air from the upper water jackets.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 02-19-2009, 06:37 PM
BNaylor's Avatar
BNaylor BNaylor is offline
It would help if you post your mileage and what diagnostic trouble codes (DTC) set off the SES/CEL light.
Timeslip 08/12/06
AF Community Guidelines
Old 02-23-2009, 08:31 PM
Icanfixit Icanfixit is offline
Re: 2002 GTP EngineThermo/Fuel Filter
250 is about right if your car is equiped with the 3100 V6. Its a PITA to get out. I have to do one tomorrow and from what I can tell, I'm gunna have to remove the throttle body, possiblly the exhaust crossover pipe. Unless some body here chimes in and let me know a easier way.
Old 02-23-2009, 08:35 PM
The OP has a 3.8 supercharged so the thermostat is about as easy as it gets.
4 door sedan
No Mods
Old 02-24-2009, 05:39 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Just the throttle body needs to come off on the 3100 V6. Then you can access the two t-stat housing bolts with a 13mm wrench. Make sure to replace the t-body gasket. It shouldnt take more than an hour. Plus it would be a good time to clean out your t-body and iac bore from carbon buildup.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-24-2009, 06:28 PM
BNaylor's Avatar
I recall removing the crossover heat shield may help some but you do not have to remove the crossover pipe in its entirety on a 3100 or 3400 V6. Also, one of the bolt holes in the thermostat housing is slotted meaning all you have to do is loosen the bolt and not remove it completely. I think it was the lower bolt.
Timeslip 08/12/06
Old 02-24-2009, 08:01 PM
tblake's Avatar
In God We Trust
Thats right Bob, the lower bolt, closer to the firewall. I forgot to mention.....
Old 02-24-2009, 08:11 PM
BNaylor's Avatar
Thanks for confirming that Tim.
Timeslip 08/12/06
Old 02-24-2009, 09:32 PM
I got it swapped out today, The books say it takes 2.5 hrs to remove and replace, and It took me about an 1.5 hr to do it. I was taking my time making sure nothing got broke or forgotten during R/R. I took the heat shield off and removed the heater core cross over tube also, just to get it out of the way. No big deal. Now they have heat because the old thermo was stuck open.
I did replace the Throttle body gasket. So its all good.
