Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 02-18-2009, 10:02 PM
chickmagnet chickmagnet is offline
will a 2.0L cold air intake work on a 1.8L?
i can't seem to find a cold air intake for a 93' eclipse gs (non-turbo)...will the 2.0 work for a 1.8? unless someone knows where i can find one for that year...thanks!!
"If it ain't broke, fix it til you are"
Old 02-18-2009, 10:08 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: will a 2.0L cold air intake work on a 1.8L?
No it won't. The 2.0l 4g63 is a turbo model and the intake comes off the turbo, not the intake manifold. The 420a 2.0l is laid out entirely different so that won't work also. Doing a quick search I couldn't find any neither. they do make them though. Best bet would probably get a couple to connect to the throttle body and then to a 2.5"-3" pipe and put a filter on the end of it. Be cheap.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-18-2009, 10:10 PM
david-b's Avatar
Dave is THAT guy
Ok I think I'll put my foot in my mouth. Unless the 2.0l comes in a N/T option, I guess you can use the same ones. My mistake.
http://www.google.com/products?q=1g+...num=4&ct=title
75 Monte Carlo
Old 02-19-2009, 09:42 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
There was 2.0 NA cars. Only in the 1gens though. I do believe he has a 1.8 motor.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-19-2009, 10:00 AM
ok, so whats the difference between short ram and cold air? and yes i have the 1.8l
Old 02-19-2009, 11:09 AM
david-b's Avatar
Dave is THAT guy
Short ram leaves the filter up high, away from the ground. Good top-end power.
A full cold air intake drops the filter close to the ground, to pick up the cold air flowing under the car. These are suppose to get you a little better power since the air ideally should be colder. However, you run the risk of sucking up water and hydrolocking your motor. I had one literally behind the splash shield and did ~65mph through a big puddle and almost killed the car but revved the shit out of it. If it's a little higher up, you'll normally be fine. You will lose a some low-end power, but gain mid-high.
75 Monte Carlo
Old 02-19-2009, 11:47 AM
Holset powered 420a
For the 1-2 HP difference between the two most people dont want to risk their motor on such a slight increase.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-19-2009, 01:46 PM
steviek's Avatar
steviek steviek is offline
yea i agree with the short ram being a bit safer and if you have a turbo the cold air intake doesn't do anything really.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-19-2009, 02:01 PM
cool, ill order the short ram asap ...thanks for all the info!!
