Old 02-18-2009, 09:55 PM
Vipersys Vipersys is offline
Help needed with electical!!!
I have a 92' Dodge Dynasty, 3.3l, v6 that has the fuel gauge not indicating anything at times with the low fuel light on even when it has $30 gas in the tank.The fuel pump is also not engaging at times. I'm not sure if this is an electrical issue or not, but any suggestions would be appreciated. Thank You.
Old 02-21-2009, 10:47 AM
vgames33 vgames33 is offline
Re: Help needed with electical!!!
Sounds like a bad connection somewhere. I don't know exactly how the wiring is on your car, but there is probably corrosion in the plug for the fuel pump/sending unit assembly.
Old 02-21-2009, 04:25 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
It is possible both the fuel level sender and the fuel pump share an earth.
If this has gone bad, it would explian why both are not working.
Old 02-21-2009, 05:54 PM
Moppie do you mean they both share a ground when you put earth?
Old 03-11-2009, 07:40 PM
sportedge sportedge is offline
Could be a lot of things,but i would definitely bet on a bad ground.
Old 03-11-2009, 10:09 PM
Moppie's Avatar
Master Connector
Ground and Earth are generally the samething, yes.
