Old 02-18-2009, 07:13 PM
racer77 racer77 is offline
Unhappy please help. 97
can someone please help. i need to get my car running.
heres whats going on. and the problem.
the key ignition cylinder broke. the key would not turn.so to get the cylinder out u turn key and push button. but it would not turn, so i drilled it out. i turn the ignition switch, it starts then stalls. anti theft i guess, cause theres a wire on the cylinder i took out.
new cylinder $200 so i find the whole column for $60
i take out the new cylinder
then decide to just use the whole column cause we kinda messed the old one up.
i put the cylinder back in and get the column most of the way in. still kinda hangin. hook up all wires, start car and it stalls. same as before.
i thought i disconnected the batterybefore we started, but there was still a wire connected to the terminal.???
do i need to reset a ccomputer or something?????????
heeeeeeeeeeeelp
Old 02-18-2009, 07:37 PM
3100 3100 is offline
Banned
Re: please help. 97
yes there are 5 different resistance values for the theft deterrent system if they do not match you will not start the car. try this attempt to start the car and just leave the key in run position for about 11 minutes theft light should turn off then start the car.
Old 02-19-2009, 03:10 AM
Drewx62x Drewx62x is offline
Re: please help. 97
I've had the same problem...the Passlock systems do get annoying but know worries the way to bypass it is to turn the key to on position for like 15 mins then off then start... should start right up...there also is a way to disable passlock I will look into it for you if you would like...
Old 02-19-2009, 06:07 AM
Re: please help. 97
so i have to do that everytime i start the car ???
thanks for the help
Old 02-19-2009, 06:32 AM
Smile Re: please help. 97
any other info would be great
Old 02-19-2009, 07:37 AM
Banned
Re: please help. 97
no, not every time just once. the same thing you have to do when replacing pcm and instrument cluster
Old 02-20-2009, 12:47 PM
Thumbs up Re: please help. 97
y did you all tell me that would work???
still broken
just joking with ya . it worked just like ya said
this forum saved me again
thanks alot
Old 02-20-2009, 01:25 PM
dblnaught's Avatar
dblnaught dblnaught is offline
Re: please help. 97
and that would be....?
Old 02-20-2009, 04:12 PM
Banned
Re: please help. 97
and that would be disconnecting the small connector under the key cylinder with yellow and black wires but you have to do it while the engine is running. Then turn off, pull the key out and within 3 seconds start the engine again. However, theft light will remain on but you should not have problems with theft deterrent again.
But since he already did the relearn procedure the right way I don't see the reason for doing the above mentioned, unless someone wants to mess with ignition switch and do push button start.
