85 actin up
sumtimes its hard to start then wen it does start it'll idle for a min den turn off unless i hold da gas but wen i let go it just turns off...any ideas???
Re: 85 actin up
when the engine is cold, pump the throttle pedal , the carb choke plate should be closed firmly, when the engine starts it should open quickly to create a .17in gap......... |
Re: 85 actin up
Re: 85 actin up
the choke stove is the thingy that springs the carb plate closed ..as this thingy gets hot this plate then opens slowly... if this part has become defective it loses its ability to firmly close this plate... |
Re: 85 actin up
If choke is ok, check EGR valve. If it is stuck open, car will not run right.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip, 1989 Mustang LX 5.0 5sp convertible 1992 Camry LE 2.2 1996 Suzuki RMX250 I'm a victim of circumstance [ |
HOPE THIS HELPS JOHN IN BELTON NOVAZ27 |
Re: 85 actin up
Coupeboy, let us know what happens.
I had the choke pulloff go bad on me too. I actually had to put a clip on the choke plate to keep it open while the engine was warming up, until i I figured out the problem. Oh by the way, I had lots of blue smoke pouring out the back when the problem started. Finally figured it out, paid $12 for a new choke pulloff ( Autozone), problem solved. good luck. |
Re: 85 actin up
ok i didnt do anything to it yet but now it wnt turn over...it turns like once den starts clickin, im thinkin its tha starter but i dnt wanna buy it n it not be it
Re: 85 actin up
You need a new battery or charge the one you have. Or you have bad cables.
Re: 85 actin up
wat u think coulda made it go down cuz its pretty new
Re: 85 actin up
YOU stated that you have knowledge of auto repair...why is it your asking stupid questions like this ?
don't you own a voltmeter ? do you have any tools...? so far you have done nothing, have not given any results of tests/troubleshooting info, to help you.. I think your just wasting our time ... |
Re: 85 actin up
