Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-18-2009, 06:02 PM
97eclipse-rs 97eclipse-rs is offline
Question about a 97 eclipse
i recently bought a 1997 rs-non turbo used eclipse, and every thing about it ran fine, until recently (after driving from Virginia to California) my car started to "struggle", For example if im any where between 2 and 3k rpms the car lurches forward and sometime in really bad cases makes a cracking sound. but after 3k rpms it doesnt do that any more unless im in 5th gear and i floor it. when it is "lurching forward" it seems to stall for a moment even though the rpms stay the same its almost like the fuel is being sprayed in burst into the engine and not a soild stream like i would imagine it does.
im extreamly new to cars and how they work so any input on this problem would be greatly appreciated.
Old 02-18-2009, 06:44 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Question about a 97 eclipse
Welcome to AF.
There could be a lot of things that are causing this problem. Firstly, I could start with regular maintenance. Change the spark plugs, wires, oil, fuel filter and see if that helps at all. Then run some premium gas with fuel injector cleaner through a tank and see what happens with that.
Is the car smoking at all? The the oil level drop over time? Coolant level? Check engine light on? After the maintenance and if nothing changes, disconnect the negative battery terminal for about 5 minutes and reconnect. Then drive and see if if still does the same thing.
And just for reference, the fuel injectors spray in pulses not a solid stream
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-18-2009, 07:10 PM
Question Re: Question about a 97 eclipse
i'm going to change the spark plugs and wires today, the oil was changed out last week, there is no check engine light, and from what i can tell the oil level remains the same, as far as the battery ill try that out as well, but on my drive across the country i did change the battery out because one moment it was working and the next mine it had the check battery light and then died, i had the alternator checked and everything checks out fine, also a very newbish question but where is the MAF sensor?
and im also going to check for a vacuum leak, thanks for the reply =]
Old 02-18-2009, 07:14 PM
sorry for the double post, but i forgot to answer your question about the car smoking, no its not smoking the only thing it does that is of extreme concern to me is it like makes a loud popping sound or a Crack sound when i floor the pedal , so i refrain from doing that. also i did do about 2 or 3 fuel injector cleaners and that didn't really do anything noticeable to my problem so i think the injector is OK for the time being.
p.s mine = Min. is previous post
Old 02-18-2009, 10:18 PM
david-b's Avatar
Dave is THAT guy
The 95-99 n/t 420a motors do NOT use a MAF sensor... only a MAP sensor. Not quite the same thing.
This pop/crack sound, is it like a backfire? Vacuum leaks on a n/t car won't cause huge problems, just maybe a bad idle or low falling rpm (unless you were entirely missing a whole system or something).
75 Monte Carlo
Old 02-19-2009, 02:59 AM
yeah its kinda like a back fire, but it happens some times at low rpms with me putting (or what it seems to me putting) hardly any stress on the car IE shifting in the low 2k's.
sorry i cant describe it better I'm still trying to learn all the terms and what every part is.
in reference to the MAF i just wanted to know what it looked like, it sounds fancy =]
Last edited by david-b; 02-19-2009 at 11:14 AM. Reason: Fixed my own quote. My bad
Old 02-19-2009, 09:39 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Dave meant to say the 420a motors does NOT have a MAF.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-19-2009, 11:13 AM
david-b's Avatar
Dave is THAT guy
Damn. I messed up that post. Good catch... fixed.
Change those plugs and wires and let us know how that goes. Then we'll go from there.
75 Monte Carlo
Old 02-23-2009, 06:35 PM
well i replaced the spark plugs and the cables and everything is back to normal, thank you for your help =]
im also going to change the fuel filter... once i find it.
