Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-18-2009, 02:22 PM
dddaaa dddaaa is offline
Please help! outer tie rod end boot ripped '92 ciera
Both sides of the front (rt and lf) tie rod end boots are ripped bad on my 92 cutless ciera s 3.3L. I do not notice any play in them so I plan on replacing only the boot (plan on selling car and don't wanta spend excess $ as I have already spent alot replacing alot of parts). I need advice on how to clean and what kind of grease to put in as I have already bought the 2 boots.
Thanks to everyone for all the help in the past and now!!
Old 02-18-2009, 02:40 PM
maxwedge maxwedge is offline
A990 racer
Re: outer tie rod end boot ripped '92 ciera
The joints are sealed if Oe, no way to grease them.
Old 02-18-2009, 04:53 PM
The boot is ripped on the end of the outer steering tie rod end. I can pull the boot off. I have a replacement boot that is not OE. I want to clean the old steering outer tie rod end and replace only the boot to seal the OE tie rod with the new not OE boot (putting grease on the tie rod prior to installing the boot on it. The tie rod has no play in it so I think it is good-but needs to be cleaned real good and new boot installed with grease so that it does not wear and to meet local state inspection so that I can sell the car. Can all this be done and make work right cause I am an honest guy and dont want the buyer of the car to have a problem + if I decide to state inspect prior to sale so I can say its inspected and passed (which is a good selling point). My question: 1. what spray do I use to spray on the outer tie rod minus the boot which is ripped and 2. Should this work doing this way and 3. I have a grease gun is that grease ok (I think it is ok as its used for car axils).?
Old 02-19-2009, 05:58 PM
A990 racer
When you get this apart you will see there is no way to get grease into the joint.
Old 02-19-2009, 08:33 PM
In reinstalling the tie rod end to the steering knuckle arm, the tie rod wont go through the hole all the way..it is stuck (the threads on the tie rod end are barely out the top of the knuckle but not enough to get the nut on to pull through). How do I force it through? I have the weight of the front of car on the bottom of tie rod trying to push through but wont go. Any suggestions????
Old 02-20-2009, 03:27 PM
A990 racer
It must be cocked somewhat, make sure the tie rod and steering arm hole are lined up vertically.
Old 02-20-2009, 10:57 PM
Job completed successfully. Thank you for the help.
