Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-18-2009, 01:14 PM
amp900 amp900 is offline
relay switch
how do i check a relay switch for a fuel pump for a 95 eclipse
Old 02-26-2009, 09:24 AM
Bodack Bodack is offline
Send a message via AIM to Bodack
Re: relay switch
Here's my guess as I haven't been under a hood in a little while. It's probably in the relay box under the hood. You can either test resistance of the relay or use a jumper wire to jump the two electrical points together. If the jumper wire does the trick you probably just need a new relay. Welcome to the forums.
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
