Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-18-2009, 12:51 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Clutch and Flywheel... time to buy!
With this rebuild, I'm replacing the clutch (number 3!) since the motor will be out and I get mad noise from the TOB and mad chatter. Plus I'm sure this thing is probably close to dying since I turboed the bad boy anyways.
So, I want to get a lightweight flywheel and a strong clutch. The one right now is super soft. I can push the clutch pedal down to the floor with 1 finger... when I was in Dustys car, that clutch was stiff as hell.
So my question is, where can I get a good lightweight flywheel and clutch that will be basically "plug-n-play"? What's recommended? I don't really know the difference between modular and all that jazz.
And then, I'll buy one this week!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-18-2009, 01:12 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Clutch and Flywheel... time to buy!
A modular clutch basically is a flywheel/disc/pressure plate all riveted together and is bolted to a flex plate since the flywheel doesn't have teeth on it. Not sure what you have now but I got away from this setup.
As far as what I would recommend, you have felt my clutch first hand. Fidanza flywheel and zoom stg 2 disc. I would recommend running a kevlar disc at least just because it engages really smooth and holds a lot of power. Also Im using the heavier pressure plate.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-22-2009, 01:14 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I'm a little late on this, but I am running an ACT Streetlite flywheel and a ACT 2600 clutch with a sprung 6 puck. It will take a little while to figure out how to drive it without chattering the shit out of it, and the pedal pressure can be annoying in traffic, but all in all I was very happy with my choice. It will hold a tits ton of torque too, I believe it was rated to like 550 ft lbs or something.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
