Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Commodore/VS/VT/VX
Old 02-17-2009, 10:37 PM
nickwazere nickwazere is offline
VX problems any help please!!!!
I have a late 2002 vx executive and i have had it for 3 or so months and it hasnt missed a beat untill yesterday i started having a problem where the engine just cuts out. Ill be driving and it will turn off which could be quite a problem at high speeds in peak hour traffic on the freeway. It only does it on occasions but it has happened about 6 times now and my mechanic is unsure as it hasnt happened while he has been driving for him to know where the prob lies. He thinks it could be 1 of several problems inc the computer. I was wondering it this was a common problem oin vx's and if anyone has any suggestions.
Thanks heaps
Old 04-06-2009, 06:34 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: VX problems any help please!!!!
Common for the crank pulley rubber to crack and put the crank angle sensor out. Replace the CAS and the pulley
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 06-29-2010, 05:54 AM
driffter driffter is offline
This can also be caused by a faulty DFi module (its what the coil packs attach too). Disconnect the plug on the module (should be attached by a 8mm bolt i think or mabye smaller) and check for corrosion, also retension the pins with a pick, clean terminals and connector with contact cleaner, re-fit and check . If not the DFI module may be faulty (common problem).
