Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-17-2009, 09:44 PM
bighops2000 bighops2000 is offline
Send a message via AIM to bighops2000 Send a message via Yahoo to bighops2000
Can I do these myself?
I'm no dummy and I am no stranger to a little bit of work under the hood. I have the haynes manual but there are a few things that I need to get done and I would like to try to do it myself.
1. Rear Rotors and pads all the way around. I have a regular jack (came with the car...not one of the big ones with wheels.
2. Front axel.
Its not mandatory that I try to do these myself but I like the sense of accomplishment after doing them while at the same time I don't want to get in over my head or find out I don't have certain tool. Are these do-it yourself
My car is not "raggedy"....it just needs a lot of "minor" work....
Old 02-17-2009, 11:24 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
Re: Can I do these myself?
Only you would know whether you have the ability to do your own work. We don't know what tools you have or your experience level. You want to use your emergency jack to do work? I hope you're kidding. Have you ever done a brake job? Doing a brake job on a Rodeo isn't hard but it's time consuming b/c you have to repack bearings and etc.
What do you want to do with your front axle? Again, you want use your emergency jack and not a floor jack with heavy duty stands?
Truck specs would be nice.
No offense but it doesn't seem like you have tools for the job. A proper brake job is critical.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 02-18-2009, 07:12 PM
i apologize for the vague post. this is a 97 honda passport 4wd. The reason for posting this was because I was talked out of replacing shocks since you need some tool to compress the shock. I was making sure that these jobs don't require something similar after I've already dismantled the vehicle.
Old 02-18-2009, 09:34 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Normally I would reccommend a factory manual over a Chilton or Haynes, but Isuzu factory manuals suck. I wasted $100 on one for my 2000 Trooper
Pads are easy, so are rear disks, front disks are more work.
Don't see why you'd need a compressor for shocks, coil springs yes.
DO get a real jack and jack stands, Pep Boys has sets for cheap.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-19-2009, 12:30 AM
Florsuzo Florsuzo is offline
Removing and replacing the shocks on the Passport requires nothing more than a 14mm and a 17mm socket and about 5-10 minutes per shock. There is nothing to compress other than compressing the shock slightly to get it out of the upper mounting holes (which can easily be done with your hands by pulling or pressing down). Someone has shocks confused with MacPherson struts (with coils integrated). Those require spring compressors to remove from the vehicle.
1997 Passport EX, 3.2L SOHC, automatic, 4WD, 131k.
Old 02-19-2009, 03:16 AM
Ramblin Fever Ramblin Fever is offline
BigHops....I agree...do NOT attempt any kind of work on your truck with the supplied ER jack....in fact, I tossed mine out years ago. I carry around a jack, but one much more suitable to the weight of the Rodeo.
Get jack stands or a floor jack. Easiest, IMHO, is to have both available...I generally lift the front of the truck, then place the jack stands underneith....specially while I did the front rotors/brakes/wheel bearings and ball joints.
On your 97 Rodeo...yes, if everything's original, I would definitely look into repacking your wheel bearings, check your ball joints (4), and all your rotors. The floor stands will keep the truck stabilized so you don't have to worry about the floor jack collapsing on you.
That said......I still have my rear original rotors to change out as well.
Do NOT attempt any of this with the ER factory jack, as with some of this work, you're going to be banging around on the truck/axle and the truck IS going to shift.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 02-26-2009, 05:58 PM
I ended up doing them. very easy! Glad I did. I did use a floor jack. I wasnt sure if I could borrow one before I needed to get the brakes done. If anyones on the bubble about not doing brakes IT IS REALLY EASY.
