Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-17-2009, 06:33 PM
RangerJ RangerJ is offline
Will not crank
1993 MGM 4.6 90,000 miles, new battery. Turn the key and nothing,lights horn every works battery checks okay. I banged on starter and checked connections. still no crank.Need advice
Old 02-18-2009, 07:27 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Will not crank
Have you tried to jump across the solenoid? Possible the solenoid has laid down.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-18-2009, 08:07 AM
Re: Will not crank
No I didn't try that (duh), But I will. Thanks
Old 02-18-2009, 12:47 PM
Re: Will not crank
On a whim I put the gear in nuetral and the car started fine and has started about a dozen times in park since ????? But now the speedometer doesn't work and there is a bell under the ashtray that dings 5 times pause then 5 and does this five times then stops, it does this each time you start car. Any advice?
Old 02-18-2009, 01:32 PM
Re: Will not crank
I replaced a blown fuse under the dash the beeping noise is gone and the speedo works again,should have done this before posting. Also air bag light flashing it's been doing this any cures?Thanks
Old 02-18-2009, 03:34 PM
Re: Will not crank
Okay one more time, In case I have to replace the neutral safety switch where is it located on this 1993 merc mgm. If thats my problem. thanks
Old 02-18-2009, 07:01 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Will not crank
The neutral safety switch is located on the side of the transmission. Count the flashes on the Air Bag light and that should give you a code. Check all your linkages and shift cable to be sure they are properly adjusted and all linkages are tight.
Old 02-18-2009, 08:14 PM
Re: Will not crank
Thanks for your reply, I will count the airbag flashes and post them for your help. is the nss replacement difficult to do or should I contact a real mechanic?
Old 02-18-2009, 08:46 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Will not crank
It is easily replaced. Click here for information See if it helps you any.
Old 02-20-2009, 05:20 PM
Re: Will not crank
The air bag light flashes 3 times then 4 times then starts over, Any ideas?
Old 02-20-2009, 06:49 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Will not crank
34 Driver Side Air Bag Low Resistance or Short in Circuit
There is the definition of the code 34. That might be something you may want to take to a qualified technician to be sure it works if it is needed. If you want to do it yourself, be real careful and follow any directions exactly. Good luck.
Old 02-24-2009, 05:33 PM
Re: Will not crank
Well It done it again. Been cranking good for several days. Today it wouldn't start in the parking lot,turn the key and nothing ,tried neutral still nothing as I kept wiggling the gear shift lever and turning the key it blew the fuse that controls the dash lights and speedo. This is frustating, Mechanic thinks possibly loose wire or short in the steering column. Any tips anyone. thanks
Old 03-02-2009, 03:08 PM
Re: Will not crank, It's fixed
Replaced the neutral safety switch and ignition switch and so far it is starting fine.
