Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-17-2009, 01:22 PM
SthrnSqrl SthrnSqrl is offline
2.5L Avenger Engine into a 1990 Eclipse?
I have a 1996 Avenger with a 2.5L MFI engine. The car is falling apart due to the road salt in this part of the country. I also have a 1990 Eclipse 5 Speed with a 1.8L engine.
How much trouble would it be to swap the 2.5L into the Eclipse, and would the manual tranny behind the 1.8 hold up to the 2.5?
Old 02-17-2009, 02:25 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 2.5L Avenger Engine into a 1990 Eclipse?
Anything can be swapped in if you have the money to do it. Is it a direct swap? No. Take a lot of custom fabrication, wiring, ECU, tranny, and drivetrain to get this all together. No worth it. Sell the Avenger and the 1.8 and get something worthwhile. That will be your best bet.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-17-2009, 10:38 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Maybe if you dropped the entire front subframe from the Avenger into the Eclipse. It might come close to fitting considering the Avenger and 2G eclipse had the same chassis. You'd also have to swap over all the wiring.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 02-18-2009, 10:13 PM
david-b's Avatar
Dave is THAT guy
The 1G DSMs is NOT the same frame as the 2G/Avengers. Also, how do you propose "dropping the subframe"?
75 Monte Carlo
Old 02-21-2009, 10:14 PM
drdisque's Avatar
finding common points between the 1G/2G and fabricating plates or brackets to make it work. Like I said, it's not an easy swap, but it's easier than swapping engines that have absolutely nothing in common (such as swapping in a GM or Ford V6).
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
