Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-17-2009, 12:27 PM
doc289 doc289 is offline
Camry 2.2 CYLINDER HEAD CA emissions vs Fed ,difference?
Hello i own a machine shop, and need help on telling the difference on a CA emissions and a Fed emissions CYLINDER HEAD.
thanks.
Old 02-17-2009, 07:42 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Camry 2.2 CYLINDER HEAD CA emissions vs Fed ,difference?
Not that I can necessarily help you with the answer, but I bet the answer depends on the year of the engine.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 02-17-2009, 09:50 PM
Brian R.'s Avatar
Resident Chemist
Here are some differences between the '94 California head and '94 US head:
Calif head has one distributor adjust (timing) bolt, US head has two bolts
Calif throttle body has air hose from air tube. US has TB air hose from cylinder head and no air tube.
Calif engine has VSV for fuel pressure control. US does not. (head mounted?)
'99 heads:
Calif has air hose (air assist system) attached to a cylinder head port. No hose in US head
No distributor in either head
No VSV for fuel pressure control AFAIK
