Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-17-2009, 12:23 PM
chgreenfrog chgreenfrog is offline
98 ls1 camaro motor
i got a 98 camaro with the ls1
i changed the oil not long ago and found two
bearings stuck on the drain plug magnet
i have been told this could be crankshaft
bearings or rocker bearings
told it was most likely rocker arm bearings
if anyone has any advice id be hapy to listen
thsnk
Old 03-02-2009, 07:35 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Re: 98 ls1 camaro motor
What do they look like... a round ball bearing or a long cylinder roller bearing....define the size of each !!
Dr JJ....
Old 03-02-2009, 07:52 PM
they are long cylinder looking bearings??
found two of them and they are prolly couple miliimeters long not very big at all
Old 03-02-2009, 08:03 PM
Helmuth48's Avatar
I would say....Rocker Arm Bearings.....Take off the valve covers...if you are finding these in the oil pan....you should be able to visual see the bad rocker....
Dr JJ
