Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 02-17-2009, 12:03 AM
lmbro lmbro is offline
Unhappy Alarm when unlocking with key
I just bought a 2006 Chevy Cobalt. My car alarm goes off after opening the door when I unlock it with the key. It does not turn off until I put the key in the ignition and start the car. Is this normal? The seller assures me that it is and will not do that if I get remote keyless entry installed. It is very annoying and embarassing that it goes off every time I unlock the car.
Old 02-17-2009, 07:58 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Alarm when unlocking with key
Here is some info.....
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory
Now here is how to NOT arm the car:
If you do not want to arm the system, you may lock the car with the manual lock knobs on the doors
Sounds like you have ten seconds to get in and turn on ignition- if not using a transmitter.............
If the system is armed, it can be activated by either:
• Opening the driver's door or trunk. This will cause a ten second pre-alarm chirp followed by a thirty second full alarm of horn and lights.
• Opening any other door. This will immediately cause a full alarm of horn and lights for thirty seconds.
When the CTD system is in passive arming mode, the system will arm itself one minute after the key is removed from the ignition, and the last door is closed. The doors will not lock automatically. You must press the interior door lock switch, or use the key to lock the door. If you lock the doors using the LOCK button on the keyless entry transmitter, the vehicle will lock, and the CTD system will arm immediately
Basically, you need the transmitter to do it right.............
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
