Old 02-16-2009, 10:31 PM
ripper1 ripper1 is offline
oil question need lots of help
I have a 1998 buick lesabre that blows the seal off the oil filter
What would cause this?
Old 02-17-2009, 06:19 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: oil question need lots of help
Have you inspected the filter mount sealing surface to see if a gasket from a previous filter is still attached. Not an uncommon problem with quick-lube oil changes.
Old 02-17-2009, 07:20 AM
I already checked this put a new filter on and did the same thing
Old 02-17-2009, 08:38 AM
usedranger usedranger is offline
What brand of filter? Are you overtighting the filter and deformimng it? Hand tightening is recommended but some hands are stronger than others. How long does it take to pop out of place? Another thought , are you in an area with extremely cold weather? Gaskets have been known to deform under sub-zero weather conditions.
Old 02-17-2009, 09:18 AM
BNaylor's Avatar
BNaylor BNaylor is offline
I've seen reports of this happening. In the worse cases the oil filter gets blown off and oil sprays all over.
The corrective action is the oil filter housing has to be removed. Behind that you will see a rod which controls oil pressure. In these cases the rod will be stuck in the open position which generates excessive oil pressure. So you have to get it to move freely or retract.
Once that is done and the engine is running run some Seafoam engine additive in to the crankcase for a short while to clean out the oil passages, filter assembly and oil pump. Speculation is that engine oil gunked up causing the rod to stick. After that replace the oil and install a new oil filter.
Timeslip 08/12/06
AF Community Guidelines
