Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-16-2009, 08:14 PM
willywags05 willywags05 is offline
Help
Originally Posted by willywags05
new to this i own a 92 talon 5 spd and just got dont fixing the 6 broken fly wheel bolts 2 months back. today i got satrt the car runs fine drive down the road and it only running a 500 rpms and it matted to the floor and the the car dies so i start it back up and the same rpm and dies again.. then the car wont start back up. so i have buddy push the car and i do the rolling start and still same rpms.. it wont run any higher and it keeps dieing, i dont know y if anyone has and info that could help please let me know bc i am all outa ideas!!!
I am new to this. I own a 92 Talon 5 spd and just got done fixing the 6 broken fly wheel bolts 2 months back. Today I got it started. The car runs fine driving down the road, and it's only running at 500 rpms. When I floored it the the car died so I start it back up and it ran at the same rpm and died again.. then the car wouldn't start back up. So i had buddy push the car and I did the rolling start and it still was at the same rpms.. it wont run any higher and it keeps dieing and I don't know why. If anyone has and info that could help please let me know because i am all out of ideas!!!
EDIT: Rewrote by david-b for clarity
Old 02-16-2009, 09:58 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: hellp
Welcome to AF.
Please use better grammar and sentence structure in your post. I know this is not a grammar forum but I have no idea what the hell is wrong with your car and no one is going to spend 15 minutes just trying to figure out what your saying. If you want people to help give us a good descripion that we can understand and we will try to help you.
Thanks,
-Silvr
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-16-2009, 11:53 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: hellp
Did you have the CAS out of it? Could be out 180 degrees... Or could be the ICS going out of it... Not really a whole lot of info to go off of to diagnose the problem. And yes, please use some better grammar. It will help us understand the things you explain. Thanks.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-17-2009, 10:37 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Help
It sounds like something isn't connected, whether the ISC or some other sensor. I was thinking a bad boost leak but it wouldn't be that bad if that were the problem. Is your Check Engine Light on?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-08-2009, 10:02 PM
Re: Help
here first off a few months ago i had to pull the tranny.. to find that i had broke all 6 flywheel bolts off the flywheel.. the car ran fine for about 2 months and one day i go out to it and start it up fine back out drive ran fine make it 2 blocks down the road and it start to die and running at 500 rpms even with the pedal matted to the floor.. then it died started it up and the same thing all over 500 rpms and then it dies and wont start, with a rolling start it does the same thing all over and now it wont start at all not sure y.. havent had the time to look at it. been busy pulling tranny outa a blazer. so i dont know y it keeps dieing of y is it only running at 500rpms. didnt see anything unplugged so i hope this helps. not a grammer person best i can do sorrry
Old 03-09-2009, 11:34 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Help
Unless you're 5, you can do better.
Kris
2012 Genesis Coupe 2.0t
Old 03-09-2009, 03:37 PM
steviek's Avatar
steviek steviek is offline
Re: Help
not a grammar person best i can do sorrry
irony!~
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
