Old 02-16-2009, 06:47 PM
Mark - OR Mark - OR is offline
No tail lights on 98 Silverado
No brake lights. No Haz lights on rear but front work ok.
No turn signals on rear but front work at double the normal speed. Instrument panel lights are ok. Checked fuses in
instrument panel fuse block and under hood in Fuse/Relay center. Replaced all tail light bulbs
including the tail lamp circuit boards. Where else should I look?
Old 02-16-2009, 07:01 PM
gremlin96 gremlin96 is offline
Re: No tail lights on 98 Silverado
run a wire from your batterys ground to the rear tail light. ground the tail light and see if you get it back. if that does not work your going to need a volt meter. and trace your wireing down to the plug under the spair tire. check to see if you have any power there. if not your will be chaseing it to every pinch point under the truck all the way up to the cab.
Old 02-16-2009, 10:24 PM
discnik discnik is offline
Check your trailer lights connector for corrosion, moisture, etc. I have seen this cause a good many problems in the exterior lighting wiring.
Old 02-18-2009, 11:14 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Got a bad ground somewhere back there, either from the taillight assemblies or in the trailer wiring harness.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
