Old 02-16-2009, 07:16 PM
Srmichi23 Srmichi23 is offline
Send a message via MSN to Srmichi23
How to turn on your fan Manually on a 94 lumina
i know that on a 92 lumina you can turn on the cooling fan by grounding one of the prongs from the relay. but on my 94 lumina I'm trying to do the same thing but when i checked the relay has 5 prongs so can anyone please tell me which one to ground if anyone has done it
vB code is On
Old 02-16-2009, 10:07 PM
jfitzsi1 jfitzsi1 is offline
Re: How to turn on your fan Manually on a 94 lumina
If I unplug the coolant temp sensor and start my 96 the fans will come on.
Old 02-17-2009, 04:12 PM
manicmechanix manicmechanix is offline
The '94 should be OBD1 which means you can jumper into diagnostic mode with a short wire, a paper clip or one of those metal keys from the auto parts store. this should activate your fan(s).
Old 06-24-2010, 11:13 AM
slingslingbinks slingslingbinks is offline
Send a message via MSN to slingslingbinks
When i jump the diagnostic connector to pull up the flash codes my fan come's on. Hope that helps u out
