Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-16-2009, 04:56 PM
nomiezvr4 nomiezvr4 is offline
1999 5.9 Jeep Limited Starts then shuts right off
Hey guys I've got a 1999 Jeep Grand Cherokee 5.9 Limited. Its got 100k miles. The starts up perfectly fine every single time but then immediately shuts off after a few(2-3) seconds. It will start every time but then immediately shut off whether I give it gas or not, it makes no difference.
Ive swapped the fuel pump relay with no success. The car is throwing no CEL either. I'm thinking about swapping the ASD(auto shutdown relay) as the failure of the automatic shutdown relay is often shown as inexplicable stalling or refusal to start. Has anyone else had a similar problem or knows whats going on? Thanks
Old 02-16-2009, 09:12 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 1999 5.9 Jeep Limited Starts then shuts right off
is the security system active, sounds like a typical anti-theft problem, try locking the doors with the power door locks then unlocking the door with the keyless entry system. or using the key in the door. Oh, and you said 99 5.9Limited you meant 98 5.9Limited.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 02-17-2009, 09:06 AM
I'll try it and report back today...thanks!
Old 02-17-2009, 12:44 PM
Alright, tried what you said and a few other ways...nothing worked.
Also wanted to mention that even when the car starts...the gauges don't work with the exception of the fuel gauge which slightly moves.
I swapped the ASD relay with no success. Then I jumped it with the same results.
I'm going to try to disconnect and re-connect the battery and see if that does anything. Any other suggestions?
Old 02-17-2009, 02:18 PM
Robertmchenry Robertmchenry is offline
I think dksobd1 has it somewhat correct. From what I'm told if you start the car with a key that does not have the chip embedded in the key the car will run for a second or two & then quit.
Let us know the outcome.....opcorn:
Concord, NH.
05 Jeep Grand Chrokee Laredo
