Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-16-2009, 04:11 PM
seaward00 seaward00 is offline
Question changing crankshaft and bearings?
can anybody tell me if a crank is available new or aftermarket for a 97 3.8? if so is this an expensive fix?this motor already has new gm heads upper plenhiem and injectors. i replaced the cam sensor and about 20 miles later the bottom end started hammering then she just stopped running.im thinking the bottom end was weak and when the sensor was replaced the rest of the motor started working stronger and the bearings let go .any suggestionswould be greatly appreciated thanks
Old 02-17-2009, 02:50 PM
maxwedge maxwedge is offline
A990 racer
Re: changing crankshaft and bearings?
Parts, short blocks are all available thru many sources, Napa for one. Yes this is a big job. I would suggest a good used engine here.
Old 02-22-2009, 01:07 PM
Jrs3800 Jrs3800 is offline
I agree with this... Chances are if the crank was scarred and you have to turn it more than .020 under the crank will be trash... Even better yet being that this motor must have spun a rod bearing you will have to have the Rod/Rods resized... By the time you do these small items it would have been a lot cheaper to find a Low Mileage Unit...
Old 02-24-2009, 06:15 PM
Smile Re: changing crankshaft and bearings?
im going too keep looking for a motor for my redbonnie but ive purchased a majestic teal coulored 97 se in very nice shape for 300.00 im picking it up 2moro
Old 02-25-2009, 09:04 PM
wafrederick wafrederick is offline
Banned
If you intend to keep the car,look into a Jasper reman with a 3 year, 100,000 mile warranty.The remans from parts stores are junk using the cheapest parts and the warranty sucks.Jasper uses high quality parts which are all new componets and does upgrades.An used engine has a 30 to 90 day warranty and most yards do not run them first making sure they are good.
Old 02-26-2009, 05:10 PM
How many people here that post problem have the $$$$ for a Jasper Reman?
I will say that I am lucky that I have an LKQ that is actually not a U Pull it.. And they do give 6 Month warranties on their engines..
If he searches he may find a very low mileage motor for a very reasonable price..
Jasper is a Good reman and I would recommend it to those that can afford it.. If you have the $$$$ and intend to keep the car Jasper is the way to go..
Old 02-26-2009, 06:30 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Try Ed Morad, Moradpartscompany.com. You should be able to get a good used 3.8 for less than $1000 especially since it is a NA engine.
Old 03-01-2009, 12:49 PM
Agreed on Morad... They are a class act
