Old 02-16-2009, 04:11 PM
brighteyes818 brighteyes818 is offline
Replacing CV Joint 1997
Hi,
Can anyone help, we need to replace the Cv joints on a 2.2 Chevy Cavalier 1997. Thanks a bunch
Old 02-16-2009, 04:33 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Replacing CV Joint 1997
CV nut is 30mm
Remove the caliper,rotor, all out of the way.
Either pop the lower ball joint or remove the 2 strut bolts attached to the steering knuckle.
Cv shaft is held inside the trans with a retainer clip. They are a bitch. You can use a slide hammer and a CV shaft puller which is the best idea, or use a pry bar and "pop" it with a little leverage off the side of the trans case.
Thats about it.
CV shaft nut is 185ft/lbs re-torq.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 02-16-2009, 05:16 PM
HI,
Thanks for the anwser so quick, do you just recommend the factory replacements or something better.
